Can't access ServiceFramework - skin problem?
I have an Angular 8 app that works fine using the Gravity skin in DNN 8.0.4.
If I switch the skin to my client's skin then I don't seem to get a context with ServiceFramework. I have gone through the skin comparing to Gravity but cannot see what might be wrong.
Any suggestions on what might be missing?
Declan
Removing this seems to solve the problem but messes up the skin!
<%@ Register TagPrefix="dnn" TagName="CONTROLPANEL" Src="~/Admin/Skins/controlpanel.ascx" %>
There's probably a skin object in Gravity that's causing the Services Framework script to be registered.  You can manually request it by calling <code><a href="https://dnndocs.com/api/DotNetNuke.Framework.ServicesFramework.html">ServicesFramework</a>.Instance.<a href="https://dnndocs.com/api/DotNetNuke.Framework.IServicesFramework.html#DotNetNuke_Framework_IServicesFramework_RequestAjaxAntiForgerySupport">RequestAjaxAntiForgerySupport()</a></code>.
Problem solved.
Thank you Brian.
