Cookie Consent won't show unless a module has a DNN:Label Tag
What should a modify on my SKIN file to enable the Cookie Consent pop-up to show?
I discovered that it will only pop-up if I add the following code to a module that is on the page:
<code>&lt;dnn:label ID=&quot;Label1&quot; &#114;&#117;nat=&quot;server&quot; Text=&quot;&quot; CssClass=&quot;placeholder_label&quot; /&gt;</code>
<code><img alt="" src="https://i.stack.imgur.com/nNGUN.png" title="" /></code>
<code><img alt="" src="https://i.stack.imgur.com/qKfRH.png" title="" /></code>
Posted By Tig7r on 20 Sep 2021 11:46 AM
<code><dnn:label cssclass=""placeholder_label"" id=""Label1"" &#114;&#117;nat=""server"" text=""""></dnn:label></code>
There was an issue where a needed js file was not loaded by default (dnn.js)
See also: https://github.com/dnnsof...Platform/issues/2695
Your inclusion forces dnn.js to be loaded I think.
If you upgeade to 09.10.01 the issue should be fixed.
Thanks, we were on version 9.04.01, the latest version fixes this.
