Custom breadcrumb control
Hello,
I am trying to replicate and extend the native breadcrumbs control. I have made a copy of the files but in the code behind, I am not able to compile the code because it uses Globals.DependencyProvider that is marked as internal to the platform. This is used to get the INavigationManager.
In this PR ( https://github.com/dnnsof...n.Platform/pull/2795 ) is the correct way of using DI, using the correct base classes, but for what I can see, this was not implemented in the SkinObjectBase.
So I think I have 2 options:
- Request that SkinObjectBase also has access to the DI;
- Use another class as base for this control. Ex: SkinBase already has a navigation manager accessible.
Does anyone have some kind of advice on how to go from here?
Thanks!
Maybe not a direct anwer to your question but you can also create breadcrumbs using DDR menu.
As that's fully templatable, there might not be a need to fork the breadcrumbs at all.
Examples: https://demo.40fingers.ne...Examples/Breadcrumbs
Thanks Timo!
I will give it a go and try to get away with DDR and xslt.
Actually I also wanted to add some special context and rules on some nodes based on conditions stored in portal settings, but that might be done using custom tokens ou something similar I suppose.
Anyway, I will keep looking for a workaround for this Dependency injection on SkinBase derived components.
You can switch DDR to use a Razor template and do all of the programming that you need to do.
I think that there are lots of us who have a lot to learn about using the new DI stuff ...
Tanks Timo and Joe!
Wow, the power of DDR is almost infinite.
I managed to use it with one of the Timo's templates for breadcrumbs and added some TemplateArguments so I can implement my logic.
The goal was to add special links connecting parent / child portals based on portal settings and that was accomplished.
Thanks guys!
In case someone else is looking for a similar solution, this is what I've done:
Created an ASCX for my breadcrumb control.
[code]
<%@ Control Language="C#" AutoEventWireup="true" CodeBehind="AlgoBreadCrumbs.ascx.cs" Inherits=".....AlgoBreadCrumbs" %>
<%@ Register TagPrefix="ddr" TagName="MENU" Src="~/DesktopModules/DDRMenu/Menu.ascx" %>
<%@ Register TagPrefix="ddr" Namespace="DotNetNuke.Web.DDRMenu.TemplateEngine" Assembly="DotNetNuke.Web.DDRMenu" %>
<ddr:menu id="mnuBreadCrumb" menustyle="Menus/Breadcrumbs" runat="server"> [/code]
In the code behind, I just add the template args when child controls are created:
[code]
public partial class AlgoBreadCrumbs : SkinObjectBase
        public string ParentPortalLink { get; set; } = "https://someportal";
        public string ParentPortalName { get; set; } = "Parent Portal";
        /*DDR menu structure and parames takenfrom this thread:
        https://dnncommunity.org/forums/aft/1286#4501
        public AlgoBreadCrumbs()
        protected override void CreateChildControls()
            base.CreateChildControls();
            SetMenuTemplateArgs();
        private void SetMenuTemplateArgs() {
            if (mnuBreadCrumb.TemplateArguments == null)
                mnuBreadCrumb.TemplateArguments = new System.Collections.Generic.List();
            mnuBreadCrumb.TemplateArguments.Add(new DotNetNuke.Web.DDRMenu.TemplateEngine.TemplateArgument { Name = "ParentPortalLink", Value = ParentPortalLink });
            mnuBreadCrumb.TemplateArguments.Add(new DotNetNuke.Web.DDRMenu.TemplateEngine.TemplateArgument { Name = "ParentPortalName", Value = ParentPortalName });
 [/code]
Finally I add the params to the xsl template:
[code]
xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xsl:output method="html"
xsl:param name="ParentPortalLink"
xsl:param name="ParentPortalName"
[/code]
Once again, thanks guys!
Yes, DDR is pretty powerful. So that's why, for most applications I use the UlTokens template!
