Customize DNN menu to show mega menu.
Dear all, I am new member with DNN. I installed DNN 9.2 and try to learning on this framework. I am researching the DNN menu. It have some topics on the old communication site help on display DNN menu with mega menu. But when I search some real case they only apply mega menu for one or two tab only (not all tabs). As the page https://www.dnnsoftware.com, they only apply mega menu for tab Commnunication . I don't know how to do it.
Go to dnndocs..com and look at the documentation for the DDR Menu. You'll find it in the Designers section under Theme Objects.
DDR Menu is quite customizable, so it's very possible that the theme you are using is set up to apply the mega menu styling only to certain items.
You should also be aware that the mega-menu provided with the DDR samples is quite a few years old, and you may be able to fine something more recent. For example, there is a DNN Creative tutorial at dnnhero.com that shows how to build a DDR template for a standard Bootstrap menu.
+ when you want to create a different sub menu for certain root menu items you would probably need to add this logic to your menu template.
Either in xslt or razor.
