DNN 9.5 install cannot load themes
 Could Not DNN 9.5 install  throwing the error :: Could Not Load Theme: /Portals/_default/Skins/Gravity/2-Col.ascx, Error: The file '/Portals/_default/Skins/Gravity/2-Col.ascx' does not exist.
Could Not Load Container: /Portals/_default/Containers/Gravity/Title_h2.ascx DotNetNuke.Services.Exceptions.ModuleLoadException: Unhandled error loading module. ---> System.Web.HttpException: The file '/Portals/_default/Containers/Gravity/Title_h2.ascx' does not exist. at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Skins.Pane.LoadContainerByPath(String containerPath) --- End of inner exception stack trace ---
Is this a clean install?
Are the files in question actually there? If not, maybe you should "unblock" the install package, extract it again, and again copy the install files to the appropriate directory. You might also have some file permission problems.
A good alternative is to install with nvQuickSite? It does all of the little things I always forget to do.
