DNN Community Theme Help
Running
  • v. 09.10.00 (0)
  • 4.8
Theme
GitHub - DNNCommunity/DNNCommunityTheme: DNN (formerly DotNetNuke) theme that is used on dnnsoftware.org
Hey Guys,
like the theme made to mimic the dnn community theme. Ive applied it to my site and all is good except two issues.
Cant seam to figure out how to get module containers to display correctly using this theme.
Recreate the issue - Apply Theme / Change a container on for example html module / style doesnt show.
- I did try another theme and was able to change the theme containers.
Just looking for help to fix this. Would like to be able to change the theme container.
- Tried to copy the files into the theme folder that currently being used.
- Tried coping the css to the built in custom css
Anyone out there I can pay to help me fix?
Also just having a space gap under my banner I need help fixing.
ended up finding the css and adding it to the custom css properties of the theme and things display ok for now.
Hi Joseph,
Glad to read it worked out. Just to add: the theme is derived from NVQuicktheme. If you go to https://github.com/nvisionative/nvQuickTheme and scroll all the way down, you are at the start of the documentation.
Hope this helps
Cheers
Tycho
