Edit a Template
Edit: Solution has been found and added to bottom of post for anyone with the same issue.
I am doing maintenance on an existing DNN site, and have not been able to edit HTML templates.
My procedure is to click settings on the module I need to change > expand Theme and template selection > click the edit button next to the HTML template.
On the resuting page I can intereact with the HTML, however there is no save button. The base of the editor says
Currently viewing: path to the html file is here
You need to copy this theme first to be able to edit it.
How do I perform the above in order to make a change to the HTML?
Solution: Template files must be edited by FTP.
It's not clear what you mean by "HTML Templates."
Are these HTML Templates for Theme/Skin pages? If so, you need to "parse" them after editing them.
These days, people rarely use the HTML form of Theme/Skin development. Generally it's quicker/easier to edit the corresponding .aspx files.
