Hi everyone,
I am looking to find out if the Gravity theme is compatible with the current version of DNN (9)
I am running thisthem on version 07.04.02 (216) and would like to upgrade the DNN version to its most version.
Thanks,
Sanaz
Hi Sanaz,
I think that Gravity will be quite compatible with DNN 9, but I've never tested it. You can try the most recent out-of-the-box Xcillion or the Xcillion2, which will suit better with DNN 9.
You'll have to upgrade by steps, to ensure the correct upgrading of all DNN components (www.dnnsoftware.com/wiki/suggested-upgrade-path), and don't forget to backup your system before performing any major change.
Thank you Joe. I would do that.
Thank you Francisco.
