Replacing Aperture menu with DDRMenu mega menu
Hi all,
I’m on DNN 10.0.1 and trying to switch from the stock Aperture menu to a nicer mega menu with DDRMenu templates.
What works today
  • Header uses the default Aperture menus
    <code>&lt;dnn:MENU id=&quot;menu_desktop&quot; &#114;&#117;nat=&quot;server&quot; CssClass=&quot;aperture-d-none aperture-d-md-block&quot; MenuStyle=&quot;menus/aperture&quot; NodeSelector=&quot;*,0,2&quot; /&gt; &lt;dnn:MENU id=&quot;menu_mobile&quot; &#114;&#117;nat=&quot;server&quot; CssClass=&quot;aperture-d-flex aperture-d-md-none&quot; MenuStyle=&quot;menus/mobile&quot; NodeSelector=&quot;*,0,2&quot; /&gt; </code>
  • Site: https://azmanagedit.com/
What I tried
  • Dropped the Mega2DNN template files into:
    • DesktopModules/DDRMenu/NavigationTemplates/Mega2DNN
      (has menudef.xml, Mega2DNN.xslt, Mega2DNN.css, hoverIntent.js)
  • Then tested MenuStyle="Mega2DNN" and also relative paths like
    MenuStyle="menus/Mega2DNN/menudef.xml" (from skin folder).
Problem
  • DDRMenu throws: “Couldn't load menu style … Illegal characters in path.”
    (Same message whether I reference by style name or relative file path. Using [SKINPATH] fails too.)
Ask
  1. What’s the correct way to register and reference a DDRMenu template so I can use MenuStyle="Mega2DNN" without the path error?
  2. Is there a recommended mega-menu template (Razor/XSLT) that’s modern, accessible (keyboard/ARIA), and works well on DNN 10?
  3. Any examples of minimal header markup + where to place CSS/JS for DDRMenu templates (skin folder vs DesktopModules) you’d suggest?
Happy to move files wherever DNN expects—just need the right pattern to get past the path error and recommendations for a clean, production-ready mega menu.
Thanks!
Posted By D0rk52 on 10/3/2025 7:40 PM
Hi all,
What works today
    <code>&lt;dnn:menu cssclass=&quot;aperture-d-none aperture-d-md-block&quot; id=&quot;menu_desktop&quot; menustyle=&quot;menus/aperture&quot; nodeselector=&quot;*,0,2&quot; &#114;&#117;nat=&quot;server&quot;&gt; &lt;dnn:menu cssclass=&quot;aperture-d-flex aperture-d-md-none&quot; id=&quot;menu_mobile&quot; menustyle=&quot;menus/mobile&quot; nodeselector=&quot;*,0,2&quot; &#114;&#117;nat=&quot;server&quot;&gt; </dnn:menu></dnn:menu></code>
What I tried
Problem
Ask
Thanks!
You must be on an upgraded installation?
I don't see them in my Fresh DNN 10 test install and to be honest I wonder if they still work..
Hey Timo its a fresh install.
Did you check if the file in that location exist, I don't think they do. I went back to a local DNN 6 and they were not present
I have a lot of examples here, but no mega menu: https://demo.40fingers.net/dnn-ddr-demo-skin/
any alternatives
I was messing with this one
https://github.com/MarkXA/ddrmenutemplates
also tried a custom one
and ddrmenu
then i was editing my header.ascx
This is how my current menu looks just looking to improve this
AFAIK, you can skip the /menudef.xml part of the path.
Also I would definitely place the menu template folder inside you Theme's folders.
That worked nice man thanks!!!
Does Aperture also work in DNN9? bootstrap 5?
Aperture does not have bootstrap and uses css-variables that were introduce in DNN10. It was not made to be supported in DNN9 so your mileage may vary there.
