Tailwind on DNN 10 is overwrite by _reset.scss (default.css)
Was trying to create a simple DNN 10 Theme using Tailwind CLI.
Nothing fancy on input.css, just
@import "tailwindcss";
Generate output by run cmd:
npx @tailwindcss/cli -i ./css/input.css -o ./css/output.css --watch
And play with UI.
But somehow all padding, margin, border, font got overwrite by _reset.scss (default.css)
Causing the UI that's suppose to be working, got mess up.
The DnnCssInclude priority was set to 110 but still got ovewrite by _reset.scss
I can remove the default.css with 40Fingers Stylehelper, but this will causing Edit Content & Module Settings UI got mess up
Wonder if there's a better solution.
I'm no sure this has anything to do with the order as that should already be correct..
(default.css first skin.css after that)
I don't use Tailwind, but can't it deal with these resets? That seems weird to me..?
Still cannot make it work, seems conflict with tailwind.
I'll exclude default.css and use another skin for Edit Layout.
Hmm, I just tested injecting the reset.css into an online Tailwind editor and it did not seem to influence the layout.
Would you mind giving me a copy of the theme so I can test locally?
Because if that reset is influencing Themes, that's not good.
Sure,
You can grab it on https://github.com/erw13n/TailwindTheme
I think the problem is not DNN but Tailwind 4.
I try downgrade it to Tailwind 3.5 and seems working fine.
Posted By Erwin on 6/28/2025 10:39 PM
Ah ok.
Thank you for letting us know :-)
Posted By Erwin on 6/28/2025 1:39 PM
Yeah... this is why I was never a fan of this direction of DNN 10.  These new and untested dependencies are keeping us from really being able to support DNN 10 right now.
Tailwind 4 is introduction of CSS Cascade Layers.
All the styles that generated was now inside @layer.
Anything defined outside of @layer is stronger than @layer https://developer.mozilla...S/@layer#description
Since DNN default.css is not inside @layer, it's stronger than @layer.
A quick solution would be modify default.css, and wrap it in @layer, this will make Tailwind.css stronger than default.css
7 Helpful Replier
Erwin, very nice work proposing the fix!!
Dnn.Platform - Issue #6686
