The action menu of containers are on wrong place and moving for the mouse over
Yma
I upgraded my DNN website to DNN 9.8.1
Everything is working fine. But when I go to the edit mode, It is difficult to edit now. The action menus of all containers are at the wrong places here and there and if I move the move on it, then it is moving to a different place.
Please, can you advise me on how to fix this issue?
Thank you!
I would suspect that this is a skin/theme/container issue.
To check whether this is or is not the problem, I would recommend that you create a test page and apply the Xcillion skin. Add an HTML module, and make sure that it uses an Xcillion container. Do the problems still happen?
Yma
Yes. This issue is fixing when I am using the Xcillion skin and container. So why I am getting this error for the other skin. How can I fix this issue?
Yma
I fixed this. The problem was with the custom CSS.
We removed the body{ overflow-x: hidden; } code from the Custom CSS.
Thank you for supporting me.
Glad you got this fixed!
