Unable to assign theme to Home Page
I installed the Tahoe theme on my new DNN 9.2.2 instance and was able to configure the theme on the home page.
I then upgraded to DNN 9.4 with no issues.
But after upgrade I am unable to access the Home page settings through the page manager
Update: I was able to add Multiple Pages. But this did not allow me to edit the Home page settings.
As soon as I add an additional single page I was then able to edit the page settings for the Home page.
Update2: It seems as if you are unable to edit the settings of the page you are on. IE if you access the page manager from the Home page you are then unable to edit the Home page settings.
Has anyone else seen this? Does anyone have a solution to this problem?
I just did a clean install of DNN 9.4.0.
The site has a single page. I am able to edit page settings using the Persona Bar Pages item. I am also able to edit the page settings by going to Edit Mode and using the page settings icon from the bottom bar.
You might want to switch your theme to Xcillion temporarily and see if this fixes things.
You might also want to check with Mandeeps' support and inquire if you need to update your theme.
I upgraded from DNN9.2.2 to DNN 9.4 and this issue remains a problem.
I see others have the same isssue.
It doesn't seem to be a Mandeeps issue
Can you post links to similar reports?
How do you know it isn't a Theme issue?
Because it is happening in the std xcillion theme too.
Go have a look on Github - it's a thing with 9.4
