Visualizer Template - If Statement Only Working in Test
In the comments below is my visualizer template. Everything works perfectly on the test site, and everything except the {% if imageURL !='' %} statement works perfectly on production. The content type configuration is identical.
imageURL is a new field I added because the assets field duplicates images on the server when uploaded, so I want to use the URL of the image instead, but don't want to break all the images currently being used by the assets field. If I have an image URL, I want to use that; if I don't, I want to use assets.
On production, only the first statement is being recognized. So, when configured as below, only the imageURL field is used. If I reverse the statement, only the assets field is used.
Again, it works fine on test when configured as below and all configuration on production (as far as I can tell) is the same. Any ideas what might be happening?
Thanks!
