Xcillion 2 menu bar overlay problem
Xcillion 2 is quite a good theme, but I have one problem with using navigation bar / drop-down menu:
- when you use navigation menu bar or drop down menu (smartphone / tablet view) it visually cover main page content (text / photo), but it seems that links associated with that content are in most top layer on the page.
As a result - when you want to click on link in menu - its trigger links beneath from underlaying content (content from the page).
Page(s) with problem URL: https://krscanstvo.eu
This is NOT 2sxc modules issue - You can see same behavior on https://lokalno.eu (testing site) for Connect and Participate section (original DNN after-installation content).
(Additionally - I've placed .jpeg images illustrating problematic behavior on my GDrive - link)
Now - I have found .js that control menu bar behavior for that skin (at least I think that's the one) in:
/Resources/assets/vendors/smartmenu1.1.0/jquery.smartmenus.min.js and associated sm-core-css.css with following code:
/* Mobile first layout SmartMenus Core CSS (it's not recommended editing these rules)
   You need this once per page no matter how many menu trees or different themes you use.
.sm{box-sizing:border-box;position:relative;-webkit-tap-highlight-color:rgba(0,0,0,0);}
.sm,.sm ul,.sm li{display:block;list-style:none;margin:0;padding:0;line-height:normal;direction:ltr;text-align:left;}
.sm-rtl,.sm-rtl ul,.sm-rtl li{direction:rtl;text-align:right;}
.sm>li>h1,.sm>li>h2,.sm>li>h3,.sm>li>h4,.sm>li>h5,.sm>li>h6{margin:0;padding:0;}
.sm ul{display:none;}
.sm li,.sm a{position:relative;}
.sm a{display:block;}
.sm a.disabled{cursor:default;}
.sm::after{content:"";display:block;height:0;font:0px/0 serif;clear:both;overflow:hidden;}
.sm *,.sm *::before,.sm *::after{box-sizing:inherit;}
Since positon is used in css, I was thinking of adding z-index, but not sure on which style to implement it and would this resolve problem...
Any experience with similar problem?
Any idea how to solve this?
Tnx in advance.
Have you fixed this?
Unfortunately not. I've tried, but gave up at the end  - some other tasks were of higher priority...
This is Xcillion 2 which is different than the theme distributed with DNN, right?
Right! Here is the link; https://store.dnnsoftware...tails/dnn-xcillion20
I choose this one mostly because of floating/stick-to-top menu bar, but it seems that changes in CSS are not well done.
Have you approached the theme's developer about this issue? If not, that might be a good thing to do.
What I've learned from some other online conversation (https://github.com/dnnsof...atform/issues/2559), is that developers abandoned any further work of that skin, so I supposed that it won’t help much to contact them. Because skin is free to use (no charge), there is no legal obligation either.
My only hope was that someone already run in to this problem and solved it.
However - thank You for your effort!
Edit:
I am testing right now this skin https://github.com/2sic/d...tstrap3-instant/wiki and will probably give up on Xcillion 2
If you are looking for a (free) skin, I would recommend
All of them are very flexible (especially the first one), free, open-source, responsive...
Or have a look at nvQuickTheme, if you want to create your own one.
Thank You Michel! Those are great skins and I already tried them all. They will surely be used in some of my next projects.
For this particular project I decide to go with 2sic Bootstrap 4 Instant skin (link), because of simple css re-use across modules and content when used with 2sxc App.
Thank You guys once again. Hope this topic will at least offer some solution in way of choice from above mentioned skins / themes for people who face the same problem as I was.
