Application Error
Hi All,
I am new to DNN just installed DNN version 9.11.0 yesterday on my local. Till 1 hour before it was working fine. But now when I open url dnndev.me it is giving me following error.
Application Error
On having a look at log file I have noticed following error message
023-10-17 18:22:36.490+05:30 [IXC1-LT4DB7HK3][D:2][T:39][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
   at System.Web.UI.Control.d__225.MoveNext()
Juist for your information I have just installed DNN project template 1 hour before from below mentioned url. Also I have created a sample project in .NET using DNN Project template on my local at some random path but later deleted that project. I am now feeling helpless. Please help me on this.
https://github.com/ChrisH...leases/tag/v10.03.00
Regards
Tarunjit Singh
FYI - I have moved your post to a more appropriate forum.
Have you checked in IIS to see if there are any random applications created in the <code>DesktopFolders</code> directory?  If you see it, delete the application and restart the website.  That's a common bug that either still does or always used to have happen with those development templates.
Hi Will,
Thanks for your timely help. Its working fine now.
Regards
Tarunjit Singh
Posted By Tarunjit on 10/17/2023 8:39 PM
Hi Will,
Regards
Tarunjit Singh
Awesome!  Was the fix what I described, or was it something else?  🤔
