Auto Login
I'm trying to automatically log in a user that is coming from another portal where they were already logged in. I pass an ID value that allows me to retrieve the username and password from an external table that I use for authentication. When logging in normally I use ICG's External Database Authentication provider.
After retrieving the username and password, I attempt to use UserController.ValidateUser and upon success UserController.UserLogin. It keeps returning LOGIN_FAILURE on validation as the status. However, when I pass the login information for my host account it works, and logs in the host account.
One of the parameters for Validation is the AuthType. I've tried both the default "DNN" and "ICGCustom" which is the authtype for the ICG provider. Host account only works when using "DNN".
Any thoughts would be appreciated.
OK, so I have figured out the first half of my issue. The ICG provider authenticates off my external security database. Then logs the corresponding user from asp.net_membership table. However, it must be doing so without passing the password which did not match what is in my external database. I updated the password in DNN for my test account and after doing so it works. Now I just need to figure out how they are doing that.
I found the following post which gave me my answer...
https://stackoverflow.com...ssword-in-dotnetnuke
Apparently the UserController.UserLogin does not require that the password be supplied in the UserInfo passed to it. This surprised me.
Posted By John Svoboda on 12 Jul 2022 01:49 PM
Well, you should realise this method is probably used to login users the already have been authenticated.
(which can be done using one of the DNN or a custom provider, so on "another level")
Also as this is server side code, if an attacker / user can get to the point where they can execute this kind of code, they can already do whatever they want.
