Access skin controls
Does anyone know if there is a way to access skin control through code behind in custom module?  The skin is a custom skin as well with .ascx file with asp.net controls in it.
Please provide some more details regarding your use case. What, exactly, do you need to do?
Hi Joe,
I need to be able to findcontrol(say a drop down or textbox) within page skin from custom module view code behind.
I have found a solution - hopefully someone else can benifit from this.  This can be used to get all controls or filter through list specifying control type(Label, TextBox, etc), or if control is visible or not.
var controlList = this.GetAllControls(this.Page).Where(x => x.Visible == true).OfType().ToList();
private IEnumerable GetAllControls(Control control)
            var controls = control.Controls.Cast();
            return controls.SelectMany(ctrl => GetAllControls(ctrl)).Concat(controls);
