Problem modifying logout
Creating an auth provider and I've had some success with login
But now that I'm working on logoff I can't even seem to hit the breakpoint in the authentication provider I put together.
I see logoffHandler in web.config
Not sure if it's related. Maybe I need to update the package to explicitly set my logoff as the logoff for the module?
install settings do have logoff control source set properly but that control is still not being hit on any breakpoint
Ok so searching the source I see a script that set ModuleControls to point logoff to:
DesktopModules/Admin/Authentication/Logoff.ascx
But having a setting in my .dnn file for the Authentication Module
            DesktopModules/myAuthmodule/Logoff.ascx
Doesn't update that setting in ModuleControls
I went into the DB to manually update it, I guess I need to create a sql script to do the update in the package, was hoping it would be set by the auth package definition.
If I did something wrong let me know
OK so I'm back at this issue
Creating a modified authentication process realized I needed to tell UserAuthenticatedEventArgs my Authentication Type
var eventArgs = new UserAuthenticatedEventArgs(user, msIndividual.emailAddress, loginStatus, "myCustomAuth")
But now when I try to logout it fails. I'm sure I'm missing something probably simple but the error I get back is
System.InvalidCastException: Unable to cast object of type 'ASP.desktopmodules_myCustomAuth_logoff_ascx' to type 'DotNetNuke.Services.Authentication.AuthenticationLogoffBase'.
You know how you post a question to a forum after you are certain you are stumped, and then immediately after figure out the issue.
My auth template had
public partial class Logoff : UserModuleBase
I updated it to
public partial class Logoff : AuthenticationLogoffBase
And that got me to be able to start modifying code and seeing breakpoints hit
Oh, wow... You've had quite the journey through this challenge.  Sorry, I'm just now seeing this, but I was reading through this thinking you might be missing a class, and there it is.  Thank you so much for also posting the solution!  :)
In the future, we have a working template that we usually use for authentication providers, and is about to be released in the next major release of the Upendo DNN Generator.  This will make it easier for you and others to get started in the future. Sorry it's of less help to you right now, though. :(
