Changing the title of a module control programmatically
It is easy to change the title of a module programmatically, something like
<code>private void Page_Init(object sender, System.EventArgs e){<br />    ModuleConfiguration.ModuleTitle = "Whatever";<br /> }</code>
But how can I do this for a control (eg. "Edit"). I know it is possible in the resource file by adding a key "ControlTitle_edit", but is this possible from the code behind somehow?
Hmmm... That's a fantastic question. I've never tried to do that. I've only used the resource file to update that value. 🤔
I found somethng in an old code I wrote some years ago:
<code>protected override void OnPreRender(EventArgs e)<br /> {<br />    ModuleContext.Configuration.ModuleTitle = Localization.GetString("Whatever", LocalResourceFile);<br />    base.OnPreRender(e);<br /> }</code>
I am sure that worked at the time I wrote it, but it does not anymore. I tried to use this instead of the code above:
<code>protected override void OnPreRender(EventArgs e)<br /> {<br />    ModuleContext.Configuration.ModuleControl.ControlTitle = Localization.GetString("Whatever", LocalResourceFile);<br />    base.OnPreRender(e);<br /> }</code>
No luck. Anyone who can bring light into the darkness? Is it a bug?
I recently had this exact same need and found what you have works in the OnInit function:
[code] protected override void OnInit(EventArgs e) {      ModuleConfiguration.ModuleControl.ControlTitle = Localization.GetString("Whatever", LocalResourceFile);      base.OnInit(e); } [/code]
Be sure to have Whatever.Text as the name for the string in the .resx file.
Posted By Ryan Jagdfeld on 9/5/2023 1:14 PM
Oh wow... Now that I'm seeing this code sample, it's reminding me that this is something I USED to know!  🤣
