CKEditor - Set value inside Repeater_ItemDataBound
Hi everyone
on DNN 9.12.0 I am using TextEditor (CKEditor) inside a Repeater. Inside Repeater_ItemDataBound I try to set a value to the TextEditor. The following error occurs: 'txtHeaderText.Text' threw an exception of type 'System.NullReferenceException'.
I am using the following:
.ascx
<%@ Register TagPrefix="dnn" TagName="TextEditor" Src="~/controls/TextEditor.ascx"%>
<asp:Repeater ID="rptHeaderFooterText" runat="server" OnItemCommand="HeaderFooterText_ItemCommand" OnItemDataBound="HeaderFooterText_ItemDataBound">
<dnn:TextEditor ID="txtHeaderText" runat="server" />
.ascx.cs
protected void HeaderFooterText_ItemDataBound(object sender, RepeaterItemEventArgs e)
    try
        var txtHeaderText = e.Item.FindControl("txtHeaderText") as TextEditor;
        if (txtHeaderText != null)
            txtHeaderText.Text = "some value";
    catch (Exception exc)
        Exceptions.ProcessModuleLoadException(this, exc);
Any suggestions? Thank you.
Martin
Try adding:
[code] if (e.Item.ItemType == ListItemType.Item || e.Item.ItemType == ListItemType.AlternatingItem) { }[/code]
The itemdatabound event does execute for the header, footer, and separators also. However, I am not sure if it does if they are not present.
Unfortunately the same error message and Editor's content still empty
Martin
BTW: Everything works fine as long as TextEditor is outside of a Repeater.
I'm not sure the text editor is meant to be contained in a repeater like that.  It would need to have some updates applied to support it, I think.  Especially some event handling.  If you wish to have a text editor in a repeated like that, you may be better off using a purely client-side HTML editor.  :)
Thank you, Will. I've changed it to Summernote's TextEditor (https://summernote.org/). Now everything works fine.
