Dependency Injection (DI) in DNN 10 in custom modules: the right way
I'm upgrading to DNN 10 and would like to know the correct way to approach DI in DNN.
In this context, I have a custom module that exposes a Web Service.
I currently have some legacy code from DNN 7, and I'd like to port it to DNN 10 using the official patterns:
[CODE]
            new PortalAliasController().DeletePortalAlias(httpAliasId);
            List allRolesInTargetPortal = new RoleController().GetRoles().OfType().ToList();
[CODE]
Is it correct to inject the necessary services/data structure this way to convert this code?
[CODE]
        private readonly IServiceScope currentScope = HttpContext.Current.GetScope();
        private readonly IPortalAliasService portalAliasService;
        private readonly IPortalAliasInfo portalAliasInfo;
        private readonly IHostSettings hostSettings;
        private readonly IEventLogService eventLogService;
        private readonly IHostSettingsService hostSettingsService;
        public MyWebService()
            this.portalAliasService = portalAliasService ?? this.currentScope.ServiceProvider.GetRequiredService();
            this.portalAliasInfo = portalAliasInfo ?? this.currentScope.ServiceProvider.GetRequiredService();
            this.hostSettings = hostSettings ?? this.currentScope.ServiceProvider.GetRequiredService();
            this.eventLogService = eventLogService ?? this.currentScope.ServiceProvider.GetRequiredService();
            this.hostSettingsService = hostSettingsService ?? this.currentScope.ServiceProvider.GetRequiredService();
[CODE]
Thanks all.
S.
No, Ideally you would use constructor injection and those services will be injected by DNN for you.
[code]
public MyWebService(IPortalAliasService portalAliasService)
[/code]
Now that will only work if MyWebService is one of DNN entry points, so it will vary a bit but if DNN instantiates it, it will provide any service you ask that is registered in DI.
Then it will also resolve services your services need down from that entry point.
There are a lot of small details to explain it all in a quick forum reply but if you need a demo, I do co-coding sessions on Discord almost every Friday and happy to show you in more details.
Thank you so much!
So that's it?
Simpler than I imagined :-D
S.
Posted By Daniel Valadas on 10/15/2025 4:49 PM
Hi Daniel, can you explain what this means "if MyWebService is one of DNN entry points" ? How is that defined? Thanks.
If we're talking about DNN 10, the short answer is that if DNN or ASP.NET is creating the type, it will have its dependencies filled via Dependency Injection. This includes ascx controls, ashx handlers, MVC controllers, Web API controllers, scheduler clients, business controller classes, etc.
The list is shorter and changes throughout DNN 9.x. WebForms support isn't there at all until DNN 10, but starting in DNN 9.4 there is support for Web API and MVC.
I read quickly, and I missed this part:
"This includes ascx controls, ashx handlers, MVC controllers, Web API controllers."
So if my class is defined as
[code]
public abstract class ServiceBase: System.Web.Services.WebService
public class MyService: ServiceBase
[/code]
should it already support automatic injection?
Yes, I believe WebService should be supported in DNN 10 as well.
I have not used WebService much but I'll trust Brian on this ;)
You can put a breakpoint in your constructor and check if you receive instances or null though to be 100% sure.
How to refactor this?
[code]
[Obsolete("Deprecated in DotNetNuke 10.0.2. Please use overload with IHostSettings. Scheduled removal in v12.0.0.")]
public RoleController()
[/code]
Rather than using the RoleController constructor directly, add an IRoleController parameter to your constructor, and it'll be supplied via DI.
If there's some reason you can't do that, or a similar situation that's not a constructor, you can add an IHostSettings parameter to your constructor, and then pass it through to the method that needs it.
