Modify React application -> AdminLogs.Web
Hi everyone,
out of necessity (but also for educational purposes), I need to modify one of the React applications bundled with DNN.
Specifically, the "AdminLogs.Web" application.
The goal is to add a combo box to filter logs by user.
Where can I start without messing around?
Thanks everyone,
S.
I'll try to ping a few others to get you a response. Traditionally modifying those application is frowned upon as when you upgrade DNN you will loase all of your customizations.
Posted By Mitchel Sellers on 10/13/2025 8:04 AM
Thanks Mitchel!
There is some documentation about it here https://github.com/dnnsof...lop/.github/BUILD.md and I do co-coding sessions Fridays on Discord (discord invite link in on the home page of this very site) if you need to hands-on help.
The only condition for the co-coding sessions is that it is about something open source related to DNN, so if you would like to contribute that to the platform, then I can help you out and as a bonus you then won't have to deal with updates breaking this new feature which I think would be great for everyone.
