Error code displays when module is placed on page
The error message is:
Error: Test is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: Could not load type 'Zevas.DNN.Module.Test.View'. ---> System.Web.HttpParseException: Could not load type 'Zevas.DNN.Module.Test.View'. ---> System.Web.HttpParseException: Could not load type 'Zevas.DNN.Module.Test.View'. ---> System.Web.HttpException: Could not load type 'Zevas.DNN.Module.Test.View'. at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throw ) at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly) at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.ModulePipeline.ModuleControlPipeline.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
First, which version of DNN are you using.
Please provide more information about the module. Is this one a custom module? How was it created and how was it installed in your DNN installation?
The error seems to relate the the .dll file that should have been installed in the /bin directory?
If this is a module that is intended to be compiled when DNN runs, something seems not to be wired up correctly. Does the manifest file specify things correctly?
Did you try to debug your code check it out the view exist or not?
