How to replace HostController by IHostSettingsService?
Hi all,
in a custom module I get a warning saying
<code>Obsolete("Deprecated in 9.7.1. Scheduled for removal in v11.0.0, use DotNetNuke.Abstractions.IHostSettingsService instead.")</code>
The line that throws this warning is
<code>DotNetNuke.Entities.Controllers.HostController.Instance.GetSettingsDictionary().TryGetValue("FileExtensions", out allowedExtensions)</code>
Can anyone provide an example of how to replace this? (beside the fact that the warning is misleading, as it should be <code>DotNetNuke.Abstractions.<span style="background-color:Yellow;">Application.</span>IHostSettingsService</code>)
Hi Michael,
If I'm not mistaken, you should simply use [code]DotNetNuke.Entities.Host.Host.AllowedExtensionWhitelist[/code].
There are more properties on the Host class, to access other settings.
Hope this helps.
Assuming that this is a WebForms module, you will want to introduce a field to store the IHostSettingsService, and typically you would initialize it in the constructor, using the DependecyProvider property that you inherit from PortalModuleBase. See https://www.andrewhoeflin...ion-webforms-modules for more details.
FYI, there's a pending pull request which would make WebForms modules work the same way as Web API controllers and MVC controllers, i.e. just introducing a constructor with IHostSettingsService as a parameter.
Thank you both,
Brian, if I understand that right, it is done like with the INavigationManager.
<code>public MyControl()<br /> {<br />   _hostSettings = DependencyProvider.GetRequiredService< IHostSettingsService >();<br /> }<br /> <br /> private readonly IHostSettingsService _hostSettings;<br /> <br /> protected void SomeMethod()<br /> {<br /> …<br />   string allowedExtensions;<br />   if (!(_hostSettings.GetSettingsDictionary().TryGetValue("FileExtensions", out allowedExtensions)))<br />   {<br />    … </code>
That did work (without the spaces inside the angle brackets), thank you...
When I try something like this:
Snippet <!--StartFragment-->
IHostSettingsService hostSettingsService = DotNetNuke.Common.Globals.DependencyProvider.GetRequiredService < IHostSettingsService > ();
<!--EndFragment-->
It doesn't work. Error: "'Globals' does not contain a definition for 'DependencyProvider'"
This error makes sense (cannot access it from my code) because DependencyProvider is internal in Dotnetnuke.dll.
internal static IServiceProvider DependencyProvider
            get
                return Globals.dependencyProvider;
            set
                Globals.dependencyProvider = value;
                INotifyPropertyChanged notifyPropertyChanged = Globals.dependencyProvider as INotifyPropertyChanged;
                INotifyPropertyChanged notifyPropertyChanged1 = notifyPropertyChanged;
                if (notifyPropertyChanged == null)
                    Globals.OnDependencyProviderChanged(null, null);
                    return;
                notifyPropertyChanged1.PropertyChanged += new PropertyChangedEventHandler(Globals.OnDependencyProviderChanged);
Therefore, I don't understand how can I get and save host settings without using deprecated code.
Any ideas?
EDIT:
It does work for example in this DNN's code:  \Dnn.Platform\Dnn.AdminExperience\Dnn.PersonaBar.Extensions\Components\TaskScheduler\TaskSchedulerController.cs, because \Dnn.Platform\DNN Platform\Library\Properties\AssemblyInfo.cs says "[assembly: InternalsVisibleTo("Dnn.PersonaBar.Library")] "
I coudn't find any way to get & save host settings from non-dnn core code.
It depends on where in your code you're referencing it. From a Web API controller, an MVC controller, or a scheduled task, you just need to add IHostSettingsService as a constructor argument (you may need to add the constructor altogether). From a control inheriting from PortalModuleBase, you'll need to use the DependencyProvider property. Otherwise, at the moment, those services are not available outside of internal code, and you'll need to stay with the obsolete code for now. The current plan is to adjust a bunch of underlying code in DNN 10 to use the dependency injection container, but there will be slight differences around object lifetime that we can't make until a major version change. Hopefully at that time everything that DNN creates will be available to use constructor injection to access the services in the DI container.
I was easier than I thought, and without using IHostSettingsService.
At least for now, I don't get any obsolete warning when using code like this:
var ctl = new HostController();
var myValue = ctl.GetString("myKey");
ctl.Update(key: "mykey",
            value: myValue,
            clearCache: true);
<!--EndFragment-->
Thanks,
H
