Error GetRouteData
We're using DNN version 8.0.4.
I'm getting the error below when my app routes to this URL when I'm trying to debug my module locally:
404 the resource cannot be found
https://dnndev.me/Home/Co...e/CYB-Direct/GAC_ID/|
The error in the event viewer is:
Object reference not set to an instance of an object.
at DotNetNuke.Web.Mvc.Routing.StandardModuleRoutingProvider.GetRouteData
I've confirmed that the controller rates and method index exist in the app...in fact this issue only started happening this morning...it was find the last time I debugged it 2 days ago.
I've un-installed the extension and deleted the page and re-installed etc. several times...I've deleted the DB and the dnndev.me folder and re-installed everything but no difference.
Any ideas?
THIS IS THE FULL ERROR:
InnerStackTrace:
   at DotNetNuke.Web.Mvc.Routing.StandardModuleRoutingProvider.GetRouteData(HttpContextBase httpContext, ModuleControlInfo moduleControl)
   at DotNetNuke.Web.Mvc.MvcHostControl.GetModuleRequestContext(HttpContextBase httpContext)
   at DotNetNuke.Web.Mvc.MvcHostControl.ExecuteModule()
Hello... FYI, I've moved your forum post to a more appropriate forum intended for questions about how to build modules and whatnot.
It sounds like the route path may not be accurate.  A tool I use to help me figure this out sometimes is mentioned in the blog article below.
https://dnncommunity.org/...eb-API-Routes-in-DNN
