ModuleAction on custom modules
Hello,
I'm adapting some modules from 7.4 to 9.11.2 and I'm facing with ModuleActions.
In simple terms, icons are not rendered while editing pages (the top right icons does not appear):
[CODE]
        public ModuleActionCollection ModuleActions
            get
                ModuleActionCollection Actions = new ModuleActionCollection();
                    Actions.Add(
                        GetNextActionID(),
                        "Provider Settings",
                        ModuleActionType.ContentOptions,
                        "Settings",
                        EditUrl("Settings"),
                        false,
                        SecurityAccessLevel.Edit,
                        true,
                        false);
               return Actions;
[CODE]
Any idea?
S.
Hello!  It looks like you're using a reserved word in your <code>Action</code>.  You shouldn't use <code>Settings</code> for any of your actions.  This is reserved for the built-in <code>ModuleSettings</code> view.  You can use pretty much anything else, but be careful when using <code>Edit</code>, depending on what you're doing overall.
Thanks Will, settings it's not the original string.
Replacing with "ABC" give the same result.:-/
S.
Well, if all you did was change the value and then rebuild, it won't have any impact.  You'll also either need to manually edit the value in the Module Controls view in the Extensions editor (persona bar), or you edit it in the DNN manifest and then "reinstall" the module to force the update that way.  Regardless, it will end up needing to be done both in the code and in the DNN manifest.
What I meant, was that I changed the string before posting the code, in order to hide some product information.
S.
Oh, then if it wasn't <code>Settings</code> before, it should have worked (assuming everything was wired up).
At this point, you'll want to make sure there aren't any typos.  Whatever it is in your code needs to be the same in the database where the module controls are defined, and also in the DNN manifest file.  I'd recommend copying and pasting whatever is already in the database, should it still exist.  Otherwise, copy and paste from your DNN manifest.
To find out what DNN is expecting:
  1. Log in as a superuser.
  2. In the persona bar, find the <code>Settings</code> section (gear icon) and choose <code>Extensions</code>.
  3. Find the extension you're working on and click the pencil icon next to it.
  4. Choose the <code>Extension Settings</code> tab.
  5. Scroll down to <code>Module Definitions</code>, and click the pencil icon next to it.
  6. You'll see a list of one or more controls.  Click the pencil icon next to the one you're working on in this post.  The resulting view will look something like the example below.
As you can see, this is using the Blog Module as the example below.  So please try to match things up to your environment.
What you're looking at below is the view where the module control can be edited, including the value you're having a potential issue with right now.  The <code>Key</code> is what should match the value we previously were discussing to be <code>Settings</code>.  The <code>Type</code> can be something that could get in the way too.  Just be sure that if it's an editing view, you specify <code>Edit</code> for the value.  This will match the permissions you apply in the module and page in the <code>Edit</code> column.  <code>View</code> should be used for module controls that you wish to respect the View permissions column on the page and module.
Thanks Will!
Maybe the problem is in the skin.
What is the HTML fragment that renders these controls?
Maybe you can check if the container uses some obsolete DNN controls like SolPartActions. ActionButtons can also be removed.
If yes, I suggest you to simply remove them because the recents DNN versions doesn't use the SolPartActions anymore to display the module menus and ActionButton will disable the menu display.
Don't forget to remove the controls registration and the corresponding tags.
There shouldn't be any HTML to review and troubleshoot, as long as everything is wired up AND there's nothing in the theme that is breaking the feature.
Do you see the actions menu in other modules?  Do those menu items appear to be working correctly?  If the answer to those questions is "yes," then the issue is with the code and the values that are registered in DNN as earlier suggested.
Do you see any other symptoms that may be contributing to the issue?  Have you checked the two event logs to see if there might be any related errors?
Thanks all guys!
@Will: the event logs was the first thing I've checked before posting.
@Stephane: maybe you got the point!
This is my container, with Solpart elements commented out...but I think something is missing..
[CODE]
<%@ Control language="vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.UI.Containers.Container" %>
<%-- <%@ Register TagPrefix="dnn" TagName="ACTIONS" Src="~/Admin/Containers/SolPartActions.ascx" %> --%>
<%@ Register TagPrefix="dnn" TagName="ICON" Src="~/Admin/Containers/Icon.ascx" %>
<%@ Register TagPrefix="dnn" TagName="TITLE" Src="~/Admin/Containers/Title.ascx" %>
<%@ Register TagPrefix="dnn" TagName="VISIBILITY" Src="~/Admin/Containers/Visibility.ascx" %>
<%@ Register TagPrefix="dnn" TagName="ACTIONBUTTON" Src="~/Admin/Containers/ActionButton.ascx" %>
div class="DeepSkyBlue01_style">
  div class="DeepSkyBlue01_top_bg">
    div class="c_icon">
      dnn:ICON runat="server" id="dnnICON" />
    /div>
    div class="c_title">
      h2 class="c_titles"> dnn:TITLE runat="server" id="dnnTITLE"  CssClass="c_title_DeepSkyBlue" /> /h2>
    /div>
    div class="DeepSkyBlue01_c_menu">
      <%-- &lt;dnn:ACTIONS runat=&quot;server&quot; id=&quot;dnnACTIONS&quot; &#160;ProviderName=&quot;DNNMenuNavigationProvider&quot; ExpandDepth=&quot;1&quot; PopulateNodesFromClient=&quot;True&quot; /&gt; --%>
    /div>
    div class="DeepSkyBlue01_c_help">
      dnn:ACTIONBUTTON runat="server" id="dnnACTIONBUTTON5" CommandName="ModuleHelp.Action" DisplayIcon="True" DisplayLink="False" />
    /div>
    div class="clear_float"> /div>
  /div>
  div class="c_content_style">
    div id="ContentPane" runat="server" class="DeepSkyBlue01_content"> /div>
  /div>
  div class="c_footer">
    div class="c_footer_l">
      dnn:ACTIONBUTTON runat="server" ID="dnnACTIONBUTTON1" CommandName="AddContent.Action" DisplayIcon="True" DisplayLink="True" />
    /div>
    div class="c_footer_r">
      dnn:ACTIONBUTTON runat="server" ID="dnnACTIONBUTTON2" CommandName="SyndicateModule.Action" DisplayIcon="True" DisplayLink="false" />
      dnn:ACTIONBUTTON runat="server" id="dnnACTIONBUTTON3" CommandName="PrintModule.Action" DisplayIcon="False" DisplayLink="False" />
      dnn:ACTIONBUTTON runat="server" ID="dnnACTIONBUTTON4" CommandName="ModuleSettings.Action" DisplayIcon="True" DisplayLink="false" />
    /div>
  /div>
  div class="DeepSkyBlue01_footer"> /div>
/div>
[CODE]
S.
