ModuleSearchBase problem
I have a custom module I need to be searchable from DNN search.
So I have added a Controller class to my module that extends ModuleSearchBase with GetModifiedSearchDocuments method. I added the namespace in the module settings.
However since I added the namespace the module crashes and throws this exception the log:
Value cannot be null. Parameter name: type
InnerStackTrace:
in System.Activator.CreateInstance(Type type, Boolean nonPublic) in System.Activator.CreateInstance(Type type) in DotNetNuke.UI.Skins.Pane.IsVesionableModule(ModuleInfo moduleInfo) in DotNetNuke.UI.Skins.Pane.InjectModule(ModuleInfo module) in DotNetNuke.UI.Skins.Skin.InjectModule(Pane pane, ModuleInfo module)
this is my controller class:
    public class ListaController : ModuleSearchBase
        public ListaController()
        public override IList GetModifiedSearchDocuments(ModuleInfo modInfo, DateTime beginDate)
            var searchDocuments = new List();
            List docs = GetDocs();
            foreach (var doc in docs)
                searchDocuments.Add(new SearchDocument
                    Title = doc.Title,
                    Body = doc.Body,
                    ... and so on ...
            return searchDocuments;
I think the problem is in the configuration side rather than code side.
DNN version is 9.4.0.
Can you help me? Thanks in advance!
If you want an example of implementing search in a module, take a look at christoc.com for his module templates.
You may find some other details at https://www.dnndocs.com/index.html
I hate it when I come to a forum post to find an answer and it points to my projects, which don't answer the question :D
I'll be updating my Module Development templates to support ModuleSearchBase very soon!!!!!!!!!!!
I love it even more when I go into the Templates and find they already support ModuleSearchBase...
Joe Craig is right again!
Things have come full circle for Hammond! 🤣
Thanks for the entertaining post - you gotta love it when you run into a situation where your former self knew something you currently don't know! LOL
