What is the right code for DNN Login
I tried to write my own login module for our platform. And I copied the code of DNN AuthenticationService from the DNN source project. But it didn't work.
Any one can give me some advice? following code is what I wrote:
private void LoginUser(string username, string password)
var status = UserLoginStatus.LOGIN_FAILURE;
var objUser = UserController.ValidateUser(PortalId, username, password,
"DNN", PortalSettings.PortalName, UserRequestIPAddressController.Instance.GetUserRequestIPAddress(new HttpRequestWrapper(Request)), ref status);
var authenticated = Null.NullBoolean;
var message = Null.NullString;
if (status == UserLoginStatus.LOGIN_USERNOTAPPROVED)
message = "UserNotAuthorized";
else
authenticated = status != UserLoginStatus.LOGIN_FAILURE;
// Raise UserAuthenticated Event
var eventArgs = new UserAuthenticatedEventArgs(objUser, username, status, "DNN")
Authenticated = authenticated,
Message = message,
RememberMe = false,
this.OnUserAuthenticated(eventArgs);
I think that we need some additional details.
First, which version of DNN?
Second, did you create a new authentication provider, install it in the standard manner, and activate it on your installation? Exactly what did you do?
And can you provide any additional details that describe "it didn't work." Are there errors in the Admin log? In /portals/_default/logs? Is there any other information on the behavior?
I have created several different authentication modules. I believe that every one of of them began as a copy of the standard DNN provider, with namespaces, etc. replaced by custom ones. Once that was installed and working correctly (You can enable the new provider and keep the original one. That means you have an working ability to login while you develop), you can proceed to add your custom code.
So, describe what you have actually done, and perhaps we can provide more helpful suggestions.
You may find this helpful, too, in spite of its age:
https://www.dnnsoftware.c...hentication-provider
Thank you for your answer Joe. According to your suggestion, I should first create an authentication provider before I create the login module. I will try to do it now and thanks for the Link for creating the provider.
