Switching to FileManager
hi -- I've inherited a DNN website that mostly consists of custom modules.
In trying to upgrade the site, I found a class that relies heavily on FileController to add files to the system and I've had to rewrite some of the code. Most of it I've figured out but I'm completely stumped on this one method and can't find an example anywhere.
The old code was this:
System.IO.FileInfo fi = new System.IO.FileInfo(mySecuredFilename);
                String contentType = FileManager.Instance.GetContentType(fileExtension);
                DotNetNuke.Services.FileSystem.FileInfo myFileInfo = new DotNetNuke.Services.FileSystem.FileInfo();
                myFileInfo.FileName = fi.Name.Replace(Globals.glbProtectedExtension, "");
                myFileInfo.Extension = fileExtension;
                myFileInfo.ContentType = contentType;
                myFileInfo.Size = Convert.ToInt32(fi.Length);
                myFileInfo.FolderId = myFolderId;
                myFileInfo.PortalId = PortalId;
                myFileInfo.Width = 0;
                myFileInfo.Height = 0;
                myFileInfo.Folder = myFolderInfo.FolderName;
                try
                    myFileId = myFileController.AddFile(myFileInfo);
                } catch (Exception exc)
I'm stumped on how to use the FileManager.AddFile method properly. I found the following but it throws some kind of date error:
System.IO.FileStream myStream = new System.IO.FileStream(myFileName, System.IO.FileMode.Create);
            try
                myFileManager.AddFile(myFolderInfo, myFileName, myStream);
            catch (Exception ex)
Could someone please give me a working example of how to add a file with FileManager?
I'm assuming that the module compiles. Is that right?
What is the error?
hi Joe,
The error is:
"SqlDateTime overflow. Must be between 1/1/1753 12:00:00 AM and 12/31/9999 11:59:59 PM."
I'm pretty stumped on why it would throw a date error.
sorry, forgot to say that the module does compile and everything works fine until it gets to myFileManager.AddFile
Is there a date field that you didn't initialize?
not that I can see. When I examine FolderInfo properties, all the date fields contain dates (UpdatedOn, CreatedOn etc)
Can you post the full stack trace from the exception? That would help narrow down which part of the code is throwing the exception. For example, if it's the call to <code><a href="https://github.com/dnnsoftware/Dnn.Platform/blob/db80b65cfc2fb3920db380c46bdaf6525c1d1f62/DNN%20Platform/Library/Services/FileSystem/FileManager.cs#L307"> DataProvider.Instance().UpdateFileLastModificationTime</a></code> then the issue has to do with how the folder provider gets the last modified time (for example, if a custom folder provider returns <code>DateTime.MinDate</code> instead of <code><a href="https://dnndocs.com/api/DotNetNuke.Common.Utilities.Null.html#DotNetNuke_Common_Utilities_Null_NullDate">Null.NullDate</a></code>).
I'm not even clear what FileManager is doing -- adding a record of the file to a db table? The file (a spreadsheet) has already been saved into a folder at this point.
sorry to be murky but I didn't create this module and not quite sure why the AddFile is being called
<code>AddFile</code> may be used to create a file record in the database, but it can also be used to update the contents of a file. Since you're passing a <code>Stream</code>, I think it's probably attempting to update the contents of the file to match the contents in the <code>Stream</code>. I would guess that you want a read-only <code>Stream</code> rather than a <code>System.IO.FileMode.Create</code> <code>Stream</code> so that the code can read the contents, but I don't think that would be related to the date error you're getting now.
hi Brian, thanks for that info.
The stack trace is:
at DotNetNuke.Services.FileSystem.FileManager.AddFile(IFolderInfo folder, String fileName, Stream fileContent, Boolean overwrite, Boolean checkPermissions, Boolean ignoreWhiteList, String contentType, Int32 createdByUserID)
at DotNetNuke.Services.FileSystem.FileManager.AddFile(IFolderInfo folder, String fileName, Stream fileContent)
at FileUtils.AddFileToSystem(String myFileName, Int32 PortalId, String folderPath, String fileExtension) in [my path to App_Code] \FileUtils\FileUtils.cs:line 162
