Using dependency injection in a controller class
Hi all,
how can I use dependency injection in a controller class (of a Webforms module) in DNN 9.8.0?
What I am trying to do is using IEventLogger (instead of EventLogController) in a Scheduler client. Something like
<code>IEventLogger _eventLogger = DependencyProvider.GetRequiredService< IEventLogger >();</code>
in the constructor. Any help is appreciated.
I'm not sure what you mean by a controller class (that could be a business logic class, a web API controller, an MVC controller, unfortunately a very overloaded term). If you were really taking about a scheduler client, you can create a constructor with takes IEventLogger as an argument and the framework will automatically fill it in from the DI container.
Brian,
thanks for the answer - it is a business controller. Sorry, I thought this is clear as I mentioned a Webforms module, and a scheduler client.
Is there some example code somewhere?
And another question: How can it be used in the IUpgradeable interface?
<code>public string UpgradeModule(string version)</code>
If you're talking about the module's business controller class, it's not currently supported to use dependency injection with a business controller class (e.g. when implementing <code>IUpgradeable</code>).
In a case where you have a controller, like <code>WidgetsController</code>, that your module and scheduler client use, you can register it with the dependency injection container and then retrieve it in any place where you have access. For places where the framework doesn't support DI yet, you'll need to manually supply an instance. For example:
<code>public class WidgetsController
    private readonly IEventLogger eventLogger;
    public WidgetsController(IEventLogger eventLogger)
        this.eventLogger = eventLogger;
    public WidgetsController()
        : this(new EventLogController())
}</code>
<code>Startup</code>
<code>public class Startup : IDnnStartup
    public void ConfigureServices(IServiceCollection services)
        services.AddTransient<widgetscontroller>();
}</widgetscontroller></code>
<code>WidgetsSchedulerClient</code>
<code>public class WidgetsSchedulerClient : SchedulerClient
    private readonly WidgetsController widgetsController;
    public WidgetsSchedulerClient(SchedulerHistoryItem item, WidgetsController widgetsController)
        this.ScheduleHistoryItem = item;
        this.widgetsController = widgetsController;
}</code>
<code>ViewWidgets</code>
<code>public class ViewWidgets : PortalModuleBase
    public ViewWidgets(WidgetsController widgetsController)
        this.widgetsController = widgetsController ?? this.DependencyProvider.GetRequiredService≪WidgetsController≫();
    public ViewWidgets()
        : this(null)
Does that address your questions? Once we're able to add support for constructor injection for WebForms and for the business controller class, you can remove those parameterless constructors.
Thanks Brian,
that answers my question. It was just because I got this warning
<code>'EventLogController.AddLog(string, string, EventLogController.EventLogType)' is obsolete: 'Deprecated in 9.8.0. Use Dependency Injection to resolve 'DotNetNuke.Abstractions.Logging.IEventLogger' instead. Scheduled for removal in v11.0.0.'</code>
in the BusinessController class - I thought there is a already a way to get rid of it.
How much of this has changed at this point? 🤔
Nothing has changed at this point, other than that we know that DNN 10 includes support for WebForms constructor injection and business controller class constructor injection.
Posted By Brian Dukes on 7/17/2023 5:36 AM
Awesome... That's great to know!  :)
