404 page issue. Unlogged appearance when reached
Hello,
I've just setup a 404 page for our DNN Website.
The page is setup to be viewable by All Users.
I've also setup a voluntarily broken link in a page for testing purposes.
When I click my broken test link, I get correctly redirected to the 404 page, but the page looks like I'm disconnected.
For example, the User.ascx Theme Object is loaded in all the Layout Templates of our website.
The 404 page uses one ot those Layout Templates, but when I access it through a broken link, User.ascx stops displaying my user name.
When I access the page through the Admin > Pages menu, it works just fine.
Same with other Theme Objects. Login.ascx doesn't even dispay anything. It usually displays "Login" or "Disconnect". Now it's just white space.
Does anyone know who to solve this issue?
Thank you
  • Accepted Answer
That is by design.
Because the 404 page can be called a lot, the page does as little processing as possible to prevent the system from getting overflooded.
It does behave like a normal page when you visit the page itself, but as soon as it serves a 404 page, it's pretty empty.
There is no way around this AFAIK.
Thank you for your quick answer Timo.
I thought it was because we were using an older version of DNN (9.6.1).
I feel like this is something that might cause confusion for a user using the website.
In our installation, we have a lot of profiled pages that also dissapear from the menu when served a 404 page.
At least I know I can stop trying to debug this.
Have a great day!
Actually, It was done on purpose for some reason, see https://github.com/dnnsof...Platform/issues/2216 for a bit of history on this.
But the good news is you can change that by passing ShowInErrorPage="true" on those skinObjects in your theme
Now be warned, if you are on the 404 page unauthenticated, you login and return to the 404 page, which is strange (which I believe was the reasoning behind the original change)
Posted By Daniel Valadas on 7/19/2024 1:05 AM
Ah, thanks I did not know that TBH.
