another too_many_redirects issue
New Member
New Member
You are a new member!
I got up this morning, and this site is down because of too many redirects. when i go to https://speckmanforsheriff.com I get Your connection is not private and the error is
net::ERR_CERT_COMMON_NAME_INVALID
This server could not prove that it is speckman4sheriff.com; its security certificate is from *.oes-colorado.org. This may be caused by a misconfiguration or an attacker intercepting your connection.
But my iis binding a are
If I go back to safety or hit the site with http: i get too many redirects...
It looks like the host name is misspelled in the IIS configuration. ".ocm" rather than .com
New Member
New Member
I saw that and fixed then forgot to take another screenshot...sad The real thing I don't understand is the error statement."This server could not prove that it is speckman4sheriff.com; its security certificate is from *.oes-colorado.org."  but I selected the speckman4sheriff.com cert???
It looks like the IIS bindings configuration don't match the portal aliases. How is speckman4sheriff.com related to oes-colorado.org? Are they in the same portal with different aliases? or different portals, etc.? Can you post screenshots of IIS bindings and DNN Portal aliases?
New Member
New Member
They have nothing to do with each other, totally separate DNN sites.
Few things to look at.
just to clarify, these are completely separate dnn instances? With different wwwroot folders?
just to eliminate, make sure the sql connection string in web.dot.config for the sheriff site is correct and not pointing to the iescolorado site (sounds dumb but ive done it before)
post a screenshot of the sites in iis and their respective bindings (not the detail just the first dialog where it shows the list of bindings)
