BACKUP - Azure which files/folders to exclude
My first website hosted on Azure and I am learning some new things.
  •  https://mitchelsellers.com/blogs/2019/09/13/diagnosing-fixing-azure-backup-failures
  • https://docs.microsoft.com/en-us/azure/app-service/manage-backup
Referring to the above mentioned articles,  I wonder what would be the best configuration for reducing errors and backup size
I am testing this one for the auto- dynamicly generated files - folders
\site\wwwroot\App_Data\Search\write.lock
\site\wwwroot\App_Data\Search     Dynamicly creaed
\site\wwwroot\portals\_default\logs    more about this one later........
\site\wwwroot\portals\0\DigArticle\Cache   Dynamicly creaed
\site\wwwroot\portals\0-System\Cache  Dynamicly creaed
\site\wwwroot\portals\1-System\Cache  Dynamicly creaed
\site\wwwroot\portals\2-System\Cache  Dynamicly creaed
Michel Sellers advices to exclude the
I am not sure about this one  because  there are other files which I have experianced were needed
like several InstallerLog20190926.config files
LogFailures.xml
\LogConfig folder
Actually I would only like to exclude the date.log.resources files created dayly.
Do you know if it is possible in  Azure backup  to use something like
\site\wwwroot\portals\_default\logs\*.log.resources
and hereby actually backing up folders, xml and InsallerLogDate.resources files
I seem to be unable to find more detailed documentation for configuration af _backup.filter
Have you tested and could you recommend/ suggest  other filetypes - folders
that could be included in the _backup.filter
Looking forward to any advice
If you use the OpenContent module, it also has a write.lock file (associated with it's Lucene search functionality) which needs to be excluded from the backup. I can't remember the exact path - I think it depends a bit on the install.
Generally you can look at the Azure backup logs, see what failed (and why IIRC) and if necessary add it to the _backup.filter file.
