changing the language pack register and login
trying to change register and login so many places to set but never can get all the places in skin controls and modules to cooperate.  one instance was able to get login to change on skin ui controls but not register.  maybe an idea is to create an edit view like when adding modules that you can go into language mode and edit these from any page instead of trying to locate them in language packs?  so if in language mode you can click on anything you can define and edit it on the spot.
Cody,
I am using the "Find in files" feature of Notepad++ for that. Select the root installation directory, enter the string you are looking for, filter the files to "*.resx" and check the box to include subfolders. Then you find the files and the keys, and can change them in the translation editor (I would not do it on the original files, as it will be overwritten by an update - better create a resource at the installation or portal level).
Another tool I use to search files is FileLocator Lite.  It's free, super fast and very thorough both before and after using its more advanced features.  :)
