DNN 9.10.02, How to add Javascript
Is there a setting in addition to the "Linkjavascriptlinksallowed" checkbox in the HTML CKeditor? I'm trying to add the Facebook news feed to tehe site, but it seems to be removing the Javascript code supplied by FB. My other sites of older versions are working fine, so perhaps there is another setting I don't know about yet?LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:LinkJavaScriptLinksAllowed:
You should be able to do this by configuring CK Editor. There are several articles in the blog about this, eg Customizing DNN’s Default HTML Editor Provider, or Help! DNN CKEditor is cleaning my HTML.
Anyway, I would not allow JavaScript directly in the editor. The (imho) better solution is to use an injection module, e.g. Will Strohl's Content Injection Module.
You could also try to use the raw version instead of the HTML version.
The HTML version will strip some stuff as defined in the HTML editor extension. Amongst them javascript, span, div etc.
If that doesn't work, you can also put the javascript in the module header or the page header.
