DNN Breadcrumb
Is anyone able to advise on the following WCAG error from the DNN Breadcrumb?​
Error: The <code>itemprop</code> attribute was specified, but the element is not a property of any item.
From line 92, column 6; to line 92, column 124
<code><b>< span id="dnn_dnnBREADCRUMB_lblBreadCrumb" itemprop="breadcrumb" itemscope="" itemtype="https://schema.org/breadcrumb" ></b></code>
<code><span< code=""></span<></code>
If you want more control of what's being rendered, use DDR Menu for your breadcrumbs.
Examples: https://demo.40fingers.ne...Examples/Breadcrumbs
Thats solved it! Many thanks Timo
