Embed Outlook Agenda
Is there a way to embed a MS Outlook in a DNN website?
or a Google Agenda?
7 Engaged Reader
Willem, if you go to the settings for each calendar service provider you can generate a widget and get that code in a HTML module. I know Gmail does, not 100% sure about Office 365.
Check out this article from Google: https://support.google.co...r/answer/41207?hl=en
Regards.
As Marco suggests, we often do this by embedding the calendar using a CRM, Calendly, etc.
Hi Willem,
There are 2 ways:
1. You share an Outlook calendar entirely
2. In a scenario where you might want to offer open time slots, you can also use Microsoft Bookings.
This is tied to your Outlook calendar(s)
Cheers
Tycho
+1 for tools like Calendly - their embed widgets are fantastic!
Is Calendly really better than MS Bookings?
Another alternative btw: https://appsumo.com/products/tidycal/
"Better" is subjective at worst, and needs to rely on requirements at best. 😉
However, Calendly has done a superb job at ensuring an easy UI/UX for all stakeholders, in my opinion.  (And it seems that David agrees, too.)
Perfectly stated Will. I was an early adopter of Calendly, but back then, they lacked in too many features. I later came back to see what had changed and was beyond impressed. The things we can do with Calendly now is outright amazing. I can't really speak to MS Bookings. :)
Was just curious for the pros and cons. I bought Tidycal because it was much cheaper than Calendly. And 15 minutes later I discovered MS Bookings which was already in my subscription.
