Error message in user management
After upgrading to 9.3.2 from 9.1 on Azure - I now get this error message. It looks to be a missing file - what is this so I know for the future and any suggestions of how to fix?
Could Not Load Container: /Portals/_default/Containers/Gravity/NoTitle.ascx DotNetNuke.Services.Exceptions.ModuleLoadException: Unhandled error loading module. ---> System.Web.HttpException: The file '/Portals/_default/Containers/Gravity/NoTitle.ascx' does not exist. at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Skins.Pane.LoadContainerByPath(String containerPath) --- End of inner exception stack trace ---
thanks
That's part of a previous skin / theme package, but when you upgrade it should still exist.
Ar you really using the Gravity theme? If not, you could reset the container of the page (or one of the modules) to one from the package you use.
I'll give that a go, thanks fo the pointer.
Using the upgrade pack again solved the problem.
