How to disable users' ability to change their password
I need to disable users' ability to change their password, since I am using AD-Pro which manages their password with our AD-system.
What is the best way to hide the 'Change Password" option in Edit Profile?
Tom
Tom,
AD-Pro is a third party extension, I would go and ask Glanton for support (https://www.glantonmodules.com/support-ticket)
Beside of that, you could try to find the client ID or style sheet class of the button/area (using developer tools of your browser) and add some style to hide it, for instance in the portal.css or any css file that allows customizations of your skin. Example:
.dnnPasswordDetails .dnnClear { visibility: hidden; display: none; }
Thanks - the css solution worked for me.
Tom
@Michael, thanks for the quick answer.
The other option is to edit file that is responsible for rendering 'Manage Password' section:  ~\DesktopModules\Admin\Security\EditUser.ascx
See here for refeerence: http://doc.glanton.com/AD...sword-change-section
Thanks Barry! I will take a look at that as well. Much appreciated.
Tom
Tom,
don't forget the "Reset Password" Link on the login form... I did it this way:
#dnn_ctr_Login_Login_DNN_passwordLink
   display: none;
   visibility: hidden;
.dnnLoginActions::after
   display: inline;
   visibility: visible;
   content: "Password-Reset is not available at the moment.";
Posted By Barry Waluszko on 06 Mar 2020 05:44 AM
FYI - this would be a core code change in DNN and should always be avoided at all costs.  It will be overwritten on upgrade and doesn't get reviewed by the DNN TAG team for security and other implications.  :)
