How to edit DNN site as HTML
So I was trying to get my website to reload when you resize your window but I also put an alert in the function and now I can’t get into my site because the alert window stops me form editing the page. Is there a way to edit the site as an HTML document?
Depending on where you actually put the javascript, there probably are several ways to do it. So, where did you put it?
If you are trying to keeps things good as browser windows or screens change size, look to a responsive theme which should do all of the work for you.
As for your question, there isn't an HTML version of your page.  That is created dynamically when the page is loaded.  If you put the code in an HTML module, you might be able to get at it from the Page Personal Bar item.  The Advanced tab includes a list of modules added to the page, and links (pencil icon) to edit them.
Hey Joe,
I put the Javascript in an html module on the homepage, but I can't edit that page anymore because of the brilliant script I wrote...
NVM I figured out what you ment! thanks Joe you're a lifesaver!!
See the note I added to my original answer. I assume you are using DNN 9.x. So, go to the Pages entry on the Persona Bar, select the page, and then select the Advanced tab. You'll see a list of the modules on the page, so click one of the pencil icons to edit the one in question.
If you need to, first browse to a page that works and open the Persona Bar there.
If you are on an earlier version of DNN, you want Page Settings.
I saw the note and everything works great now! thanks again man I really appreciate the help!
