HTML Module "Version History" Pager Doesn't work
Running DNN Version 09.13.06 (0) with Xcillion Skin and Container.
In the PortalSettings Table I increased the value for MaximumVersionHistory to 20 to keep more versions, but when I view Version History in the HTML Module that has more than 10 versions, the Pager doesn't work.  In the Browser Devtools I get the following error when I click on a page number in the Version History Pager:
ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5  Uncaught Sys.WebForms.PageRequestManagerServerErrorException: Sys.WebForms.PageRequestManagerServerErrorException: An unknown error occurred while processing the request on the server. The status code returned from the server was: 500
    at Error.create (https://preview.carltonla...2&t=2a9d95e3:5:2736)
    at Sys.WebForms.PageRequestManager._createPageRequestManagerServerError (https://preview.carltonla...&t=2a9d95e3:5:11490)
    at Sys.WebForms.PageRequestManager._parseDelta (https://preview.carltonla...&t=2a9d95e3:5:29608)
    at Sys.WebForms.PageRequestManager._onFormSubmitCompleted (https://preview.carltonla...&t=2a9d95e3:5:25637)
    at Array.https://preview.carltonla...A2&t=2a9d95e3:5:307)
    at https://preview.carltonla...2&t=2a9d95e3:5:51370
    at Sys.Net.WebRequest.completed (https://preview.carltonla...&t=2a9d95e3:5:89758)
    at XMLHttpRequest._onReadyStateChange (https://preview.carltonla...&t=2a9d95e3:5:84357)
Error.create @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
_createPageRequestManagerServerError @ ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5
_parseDelta @ ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5
_onFormSubmitCompleted @ ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5
(anonymous) @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
completed @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
_onReadyStateChange @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
XMLHttpRequest.send
executeRequest @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
invoke @ ScriptResource.axd?d=NJmAwtEo3Ir13qbuA6U3o1vvwem91PYU7cU1pmQmOaWLvVb1BkGRM6u25izzf42asiiKfr21ZJefffebtJ_zMn-5RghgCtPAyPvSKnemYh6CEC69rsYhTJWIYw_iIXyOyp5PGA2&t=2a9d95e3:5
_onFormSubmit @ ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5
_doPostBack @ ScriptResource.axd?d=dwY9oWetJoKm8KKlOpzPPyGu8HEVfp1zSa2qZjMYqGq71T6gP7hxfZggFQ7z27rlFZxj-TltR_eflw4nJDbx6IEhlYdb-s22HiFdb1JIugWN0GKcaRLB8QOw5FyTEvG2oqJWVBFH7Y0o6-xj0&t=2a9d95e3:5
(anonymous) @ VM5290:1
When a 500 error occurs, you should usually have some more details on disc at Portals/_default/logs you will find one file per day. Maybe there would be some clues in there.
Yes!  Here is what was recorded there when I click the Pager"
2024-12-05 07:19:43.726-06:00 [martserver4][D:2][T:13][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
System.Web.HttpException (0x80004005): The GridView 'dgVersions' fired event PageIndexChanging which wasn't handled.
   at System.Web.UI.WebControls.GridView.OnPageIndexChanging(GridViewPageEventArgs e)
   at System.Web.UI.WebControls.GridView.HandlePage(Int32 newPage)
   at System.Web.UI.WebControls.GridView.HandleEvent(EventArgs e, Boolean causesValidation, String validationGroup)
2024-12-05 07:19:43.772-06:00 [martserver4][D:2][T:13][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: The GridView 'dgVersions' fired event PageIndexChanging which wasn't handled. ---> System.Web.HttpException: The GridView 'dgVersions' fired event PageIndexChanging which wasn't handled.
This looks to me like a mismatch between the .ascx file and the code. The .ascx file expects a handler for the PageIndexChanging event, and the code does not provide one.
I don't know if this is an installable module. If it is then I suggest just try reinstalling it. If not then it suggests that the original programmers packaged the code incorrectly.
I extracted a copy of the DNNConnect.CKEditorProvider_09.13.06_Install.zip installer and perfromed a repair install of the module which completed sucessfully.  After restarting the website the module continues fail with the same error.
Is this the right module/provider to install?
I think the version management is not part of the Editor Provider but the HTML module.
I would not be surprised if 10+ versions has not received a lot of testing love ;-)
I think the simplest way to test if this is an issue of your installation or a bug, is to test it on a fresh install of the latest DNN version..
OK, I setup a test website with a fresh install of DNN Version 09.13.06 (0) with the Default Website template.  Exactly the same result.
In that case, probably open an issue here https://github.com/dnnsof.../Dnn.Platform/issues
Thank you Daniel, I just did.
[Bug]: HTML Module "Version History" Pager Doesn't work #6257
