Issue where css is not loading when not logged in to website?
Has anyone seen this issue? I'm seeing this on a test intranet website.
When I'm not logged in, I just see the raw content with no css. Once I log in, the site /pages look normal. I dont see the same issue on the production version of the site. The test version was recently copied from the production (db and content) .
Hello Tom:
It sounds like the file isn't available for some reason.  If you're able to see the full path in the HTML source, I'd suggest trying to load it directly and/or using the web dev console to inspect for any HTTP errors and other clues. In some cases, you may even be able to turn on debugging to determine if a rewrite rule or something else is getting in the way.
My experience is usually a typo or firewall/rewrite issue.
Hi Will -
Thanks for your response!
I did look in the console and there are multiple css pages that don't load due to this error:
http://sccintranettest/AD...dule.css%3fcdv%3d395 was not loaded because its MIME type, “text/html”, is not “text/css”.
The code and database are identical to our proiduction site, which doesn't show the issue, except for the web(dot)config. Maybe the issue is in the web(dot)config.
Any idea? thanks -
Tom
Well, in the case of a HTTP 404 error, the response itself is indeed <code>text/html</code>, so I wouldn't worry about that too much (yet).  I'd first suggest tracking down what's making it seem like the file isn't there.
