Issue with lowercase urls and redirects to secure assets after login
Hello,
We are encountering an issue with access to secure assets, within a website that has the setting 'Convert URLs to Lowercase' switched on (DNN  09.11). I was wondering if anyone knows of a way around this.
We have a form in the site where users can upload files. These files are stored in a Secure Folder, and links to these files are mailed to the marketing department. When one clicks such a link in the mail, one gets the login page, so far so good. But after logging in one is redirected to a 404-page.
The cause of this is:
  • Links to secure assets have the format: /LinkClick.aspx?fileticket=[FileTicketHere]&portal=0.
  • But the login page redirects to /linkclick.aspx?fileticket=[filetickethere]&portal=0, due to the setting: Convert URLs to Lowercase
  • And apparently the filetickets are case sensitive....
Is there a way to prevent the lowercase conversion for secure assets?
Or is there a way to make sure these FileTickets are always lowercase?
Hi Sytske,
Yes, in the Personabar choose SEO and then change Expressions. The first one is Prevent LOwercase... change that to:
profileUser|verificationcode|/Admin|/Host|/ctl|PasswordReset|resetToken|resume_action|popup
You may also want to check 'Do not rewrite URL.... This is what I have:
/DesktopModules/|/Providers/|/LinkClick\.aspx|/profilepic\.ashx|/DnnImageHandler\.ashx|/__browserLink/|/API/
Thanks for the reply.
We have exactly the same expression, at 'Do not rewrite URL...'.
So I have changed the Prevent Lowercase URL Regular Expression, to your suggestion. But I don't see the change i hoped for. I have restarted the applicaton (just to make sure). Or does it take longer to take effect?
What i see in the address bar:
  • I enter: www.domain.nl/LinkClick.aspx?fileticket=PlQbYorHlFM%3d&portalid=0
  • Then I end up at www.domain.nl/login?returnurl=%2flinkclick.aspx%3ffileticket%3dplqbyorhlfm%253d%26portalid%3d0
Should the returnurl also be affected by these expressions?
Thanks, Sytske
Try to add Login also?
Yes! Thank you!
[code] ________00000000000___________000000000000_________ ______00000000_____00000___000000_____0000000______ ____0000000_____________000______________00000_____ ___0000000_______________0_________________0000____ __000000____________________________________0000___ __00000_____________________________________ 0000__ _00000______________________________________00000__ _00000_____________________________________000000__ __000000_________________________________0000000___ ___0000000______________________________0000000____ _____000000____________________________000000______ _______000000________________________000000________ __________00000_____________________0000___________ _____________0000_________________0000_____________ _______________0000_____________000________________ _________________000_________000___________________ _________________ __000_____00_____________________ ______________________00__00_______________________ ________________________00_________________________ [/code]
Haha, big heart Thank you
