Login does not work in 1 specific language
I have a website with 3 languages.
English = default
German
Dutch
Suddenly the login on the dutch language (nl) does not navigate to the login page.
English and German language works ok.
I have a inspect snap shot of these below.
(Ihad to remove the first part because they were the same)
Somebody has any advise on this?
With regards, Ton
Dutch language
mysite(dot)com/nl-nl/Login?returnurl=%2fnl-nl">Inloggen
English language
mysite(dot)com/en-us/Login?returnurl=%2fen-us%2f">Login
Hi Ton,
What version DNN are you on?
I know that in early versions of 9 there were some issues...
Hi Tycho,
I use DNN 8.4
Regards, Ton
Let's take it step by step.
In site settings the login page is defined for eauch language.
If you are logged in as superuser and you are on nl-nl, is there a page designated as login page in the site settings (portal settings)?
Login as host.
admin->site settings>advanced
Login page = None specified
Drop down arrow does not show another page to use as login page
I do not see "Portal settings".
see earlier message
You should have at least 1 page with the login module on it available.
In the site settings the dropdown for assigning a login page, is populated by all pages with a login module. So, if that is not present and you won''t be able to login.
This is strange,
In the languages English and German there is also no login page available in the site settings>advanced>login page.
how can they login with these 2 laguages and the dutch language not?
So I have to  make a custom login page to resolve this?
Regards, Ton
804 is quite a while back (you should really upgrade) so not sure of specifics.
For the solution: yes, creating a new page 'loginpagina', add the loginmodule and assign that page as login page: should get you back on track
The other languages probably don't have anything in the dropdown as they use the default 'login page'. Available through /en-us/login and /de-de/login
So, the interesting part is why won't /nl-nl/login work?
What I did see is that if you go to de-de/login and then switch to nl-nl, you do get the login form.
The page that resolves to end ons /nl-nl/start/ctl/Login/PortalId/0
What I would suggest is to send an email to support of easydnnsolutions and see if he has any input. The login controls are included in his skin, so maybe he has encountered this before.
Hi Tycho
I will go to easydnnsolutions for advise
Thanks for the quick and help full reply
Regards, Ton
