Login Popup No Permission
in The Logfile it shows:
2022-11-25 08:42:52,252 [TS][Thread:16][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the \\ section in the application configuration. ---> System.Web.HttpException: Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the \\ section in the application configuration.
   at System.Web.UI.Page.get_Session()
   at DotNetNuke.Framework.CachePageStatePersister.Save()
   at System.Web.UI.Page.SaveAllState()
Problem solved !
The corresponding forward dns zone was deleted when the server was changed.
Posted By Martin Kaderli on 11/25/2022 5:08 AM
Problem solved !
Nice catch... Thank you for letting us know what the fix was for you.  :)
