Multiple Authentication Tabs on Login page
Hello,
After setting up DNN site, I had restored my site content and added modules. On Login page, I can now see 2 tabs, one for My Custom Login and another one for Standard Login. I want that tab to be disapear. How can I achieve that?
The below is the code portion of the login page:
<dnn:DNNTabStrip ID="tsLogin" runat="server" TabRenderMode="All" CssTabContainer="LoginTabGroup" CssContentContainer="LoginContainerGroup" DefaultContainerCssClass="LoginContainer" DefaultLabel-CssClass="LoginTab" DefaultLabel-CssClassHover="LoginTabHover" DefaultLabel-CssClassSelected="LoginTabSelected" visible="false" />
<dnn:dnntabstrip csscontentcontainer="LoginContainerGroup" csstabcontainer="LoginTabGroup" defaultcontainercssclass="LoginContainer" defaultlabel-cssclass="LoginTab" defaultlabel-cssclasshover="LoginTabHover" defaultlabel-cssclassselected="LoginTabSelected" id="tsLogin" runat="server" tabrendermode="All" visible="false">
This LoginTabGroup has 2 tabs: one my custom login and another standard tab. I dont want to show these 2 tabs options.
Can anyone suggest anything?
Sure. Which version of DNN are you using?
If you are using DNN 8 or lower, to to Admin, Extensions and open the Auhentication Settings section. Then click the edit (pencil) icon for the authentication you want to disable and uncheck the Enable box. That should do it.
If you are using DNN 9.x, go to the Persona Bar Extensions page and find the Authentication Systems page. Edit the authenticaion module that you want to eliminate, click the edit pencil and then the Site Settings tab. Uncheck the Enabled box.
That should do it.
FYI, if the custom authentication system is still under development, I would keep the default provider enabled until you are sure that the custom one is working. That way, you will have a way to login.)
Thank You. It Worked..!
