OWASP security check
How to tell your customers your website is save and secure? You can use OWASP
I found this page on the DNN website: https://www.dnnsoftware.c...st-owasp-top-10-2013
Does someone have a more recent version or where can I find this?
OWASP is an open community set of definitions. https://owasp.org/www-pro...test/2-Introduction/
I would strongly recommend not just quoting from an older community document, it may not be accurate and if something gets hacked later might leave you open to allegations of fraudulent misrepresentation.
They form part of a 'security questionnaire' you can provide to your customer. Forgive me if I am teaching granny here. These are most often independently 'assured' by an external tester. Usually as part of an ISO27001 ISMS scheme. You can self certify once you have done the checklist, though its not ideal.
As a solution, I suggest you ask your hosting provider about their ISO27001 and other compliance as the start point. You 'off-set' compliance to them. Also ask them if they have penetration testing at the hardware level. Then you point out the DNN has unique built-in security testing, and together, they give a high level of assurance though not a full penetration test (these are costly at about £3k a go)! Hope this helps, can provide a questionnaire if you want one?
Willem,
I use the following (amongst other steps):
Use certificates, and force HTTPS. Read Why EVERY site should be secured by HTTPS.
Read and follow 7 Tips to Protect your DNN Website from Ransomware.
Read and follow Tip 1: Never put Web-Files on Drive C - Harden DNN against Ransomware Attacks and future articles from this series.
To secure your database I recommend to read and follow this article: Secure your DNN database by some simple steps.
You should never ever open a port on your web server that is not needed - esp. do not allow anyone (and if they are the best tech-persons amongst your clients and really know what do do) to access the SQL Server from their computers. Get rid of FTP (except you can use SFTP - and don't confuse it with FTPS).
There are companies that do security audits. They have employed hackers who know where to look. If your customers really want to be save, they should take money into their hands and engage them.
And: stay up to date. Windows XP Service Pack 3 was secure when it was deployed.
