Possible security issues
[POST EDITED BY MODERATOR TO COMPLY WITH COMMUNITY POST GUIDELINES (see below)]
Hello SimoneDnn:
I edited your post to remove the details.  If you ever think you've found a potential security issue, you should instead follow the steps in the official DNN security policy.  This is to help protect the entire community and ecosystem, just in case there is indeed a genuine security concern.
Thank you for trying to report the potential issue!  👍🏽
Hi Will. Thanks for the information. In my defense I thought they were just problems caused by poorly made configurations ahah.  I will list the vulnerabilities using the guide. If the problems encountered were really just due to a poorly done configuration, who can I talk to? Thanks a lot
Well, basically if there is any remote possibility that something might be a security issue, it is best to post where Will suggested. This prevents exposing security issues publicly and the team can react to a fix before disclosing it and for it to become exploitable public knowledge. Should it end up not being a security issue and just some bad configuration, people there will still help with a resolution (many of the same people here) but in a more private context :)
