Restablishing Downed Site from Classic Azure VM
I mistakenly deleted a vm (classic) on Azure.  Not all was lost as the storage (VHD) for the VM was not deleted.  I have created the VM from the storage VHD file and the files appear to be in the state they were last active in.  The VM was instantated with IIS already set for the DNN app site. I removed the bindings to the domain names (and SSL requirements) to view the site in local mode via RDP and the VM browser.
I am getting an 403.14 error on the main index of the site saying: "The Web server is configured to not list the contents of this directory."
Tangentially; the BGINFO wallpaper lists the former ip that the domain name is setup for not the current VM IP... I believe this is because the BGINFO wallpaper uses a cached image from the original startup because that IP is not found anywhere in the Azure portal.  I am able to rdp using the listed VM ip address just fine.  This is why I removed the domain name bindings.
Where do I start and how do I continue to get this running for production?
Check to make sure that the default document is setup correctly. If this is a clone of a working environment then that should really not be an issue; in that case, verify you're indeed hitting the correct site/ip.
See: https://support.microsoft...n-an-iis-7-0-webpage
