Scheduler Event Failure on OnyakTech.FileShare
Hi, getting a lot of these scheduler failures, I check the scheduler and they are enabled and set to run every day. It is looking for a file or assembly, I just looked in the bin but cannot see any onyatech files.  Any ideas.
TYPE:OnyakTech.FileShare.AmazonS3Scheduler,OnyakTech.FileShareEXCEPTION:Could not load file or assembly 'OnyakTech.FileShare' or one of its dependencies. The system cannot find the file specified.
RESCHEDULED FOR:2/14/2020 11:00:39 AM
SOURCE:STARTED_FROM_SCHEDULE_CHANGE
ACTIVE THREADS:0
FREE THREADS:1
READER TIMEOUTS:0WRITER TIMEOUTS:0
IN PROGRESS:1
IN QUEUE:11
Stuart,
have you tried to contact Onyak Tech (https://www.onyaktech.com/) and opened a support ticket?
Thanks Michael, I will do that. I take it Onak Tech modules are a core dnn module
Stuart
Onyak modules are NOT core modules. "Core" modules are those that you'll find installed in a fresh install of DNN. Probably the should be called "core extensions."
Onyak is a creator of commercial modules for DNN. At some point, someone purchased and installed this module. It is quite likely that the module needs an upgrade to work correctly with your upgraded DNN install.
If you are not using the module, you can solve problems by uninstalling it.
